Omega_garage
Control your garage door(s) from anywhere, and view their current state.
The Omega_garage simply controls your garage door and allows you to retrieve the doors state (open, or closed). Using nodejs and expressjs, a web server is hosted on the the Onion Omega. The server hosts an API that allows you to control your garage doors and request their states. This makes the Omega_garage easy to integrate with any other pre-existing smart home control hub.
omega_garage allows you to control your garage from anywhere in the world. You can view the status of your garage doors and control them with with an easy to use API. This project should be able to integrate with most smart home hubs (may need to implement authentication).
Now supports sending email notifications!
Possible Improvements:
Use nodejs to create a web gui that is naturally hosted along side the API.
omega_garage.zip
All of the files needed to run omega_garage
x-zip-compressed - 1003.06 kB - 09/08/2017 at 06:34
Download
  • 1 × Onion Omega
  • 1 × Onion Omega Expansion Dock
  • 2 × Relay Get the number of relays for the number of garage doors you would like to control
  • 2 × Magnetic Proximity Sensor Get the number of sensors to match the number of garage doors you have
  • 2 × Resistors 10k Ohm
View all 7 components
  • Testing, testing, 123
    James Harding08/03/2016 at 03:41 0 comments
    So the omega_garage has been running for a week or so now. I am yet to have an issue while interacting with the garage, either through http posts, or through the actual physical buttons to open the garage. So far so good, just waiting for a power outage to happen and see what happens!
View project log
  • 1
    Step 1
    Get your Omega and Power Dock (or Expansion Dock) and run through the setup procedure here
  • 2
    Step 2
    Install nodejs
      1. opkg update
        opkg install nodejs
    1. 3
      Step 3
      Install git
      1. opkg update
        opkg install git git-http
    View all 6 instructions
    James Harding wrote 07/25/2016 at 15:24 point
    I figured someone had one out there, I just couldn't find you! It would be awesome to see your setup and source.
    Jim Esposito wrote 07/25/2016 at 15:03 point
    This looks like it's a little more along than my own Onion Garage Opener, so fantastic! :) I'll look over what you have and share mine if there's any cross-improvements possible
