USB to Parallel
A project log for WICE-4M
Leap Electronics WICE-4M EPROM Emulator Reverse Engineered
forthnutterforthnutter 12/31/2016 at 00:332 Comments
Looked at and tried a lot of off the shelf USB to Parallel and found nothing suitable. :-(
The main issue was the WICE uses LFEED signal to latch data that address other latches that the STROBE latches. Most USB to Parallel device are specified printer protocol signal. The easy way turns out to be the hard way.
Time to start looking at a custom interface.
forthnutter wrote 01/24/2017 at 11:07 point
Thanks for that info, I am looking into FT2232H.
vitecd wrote 01/24/2017 at 10:15 point
FT2232H?
