MCU Interface
A project log for WICE-4M
Leap Electronics WICE-4M EPROM Emulator Reverse Engineered
forthnutterforthnutter 02/23/2017 at 07:190 Comments
Hooked a PIC18 Demo PCB to the Parallel Port, going to control some of signals to look at how the latches are addressed.
Also hooked up AD2 to make sure I am toggling the right pins. Also when I find that laptop with built in parallel port, it will turn up one day. So I can run the original DOS based software to see what kind of data is sent.
