Interesting Waveforms
A project log for WICE-4M
Leap Electronics WICE-4M EPROM Emulator Reverse Engineered
forthnutterforthnutter 09/19/2017 at 12:030 Comments
Command's are send by latching data via the LINEFEED signal,  establishing access to three other latches were STROBE signal pushes data for reading, resetting the address counter and setting ROM or RAM profiles. RAM writes via SELPTR signal. The address counter is incremented via the INIT signal.
