Arduino - Home Automation Server
Home Automation Server is a provide a free platform that allow you to control your home from anywhere in the world.
Home Automation Server is an Open Source website that along with an Arduino or ESP8266, makes it easy to control your home from anywhere in the world.
You can create your free account at:
http://homeautomationserver.com/
And watch a Project example: "How to control a 220V Lamp Safely"
http://randomnerdtutorials.com/arduino-control-220v-lamps-from-anywhere-in-the-world/
Thanks for reading!
The complete tutorial for this project is inside the website www.HomeAutomationServer.com.
After you login you'll be able to setup everything in no time!
You can use this platform with Arduino and ESP8266:
  • 1 × Arduino
  • 1 × Ethernet Shield
  • 1 × ESP8266
View all 2 project logs
  • 1
    Step 1
    All the Instructions can be found after you create and login in your account!
View all instructions
George I Fomitchev wrote 08/15/2016 at 06:38 point
was very inspired by this project.
I belive that smart home based on Arduino is really a great tool.
johntech2014 wrote 06/17/2016 at 23:06 point
The main problem of all the home automation projects is ... You have to login to someone else's server to create an account to use it. I would like to see someone create a Home automation solution that uses an Arduino Uno or MEGA,  WITHOUT using someone else's server.  Maybe using an ESP8266-12 or a NRF24L01 group of boards. I refuse to log into someone else's server to transmit / receive my data.
plinio wrote 12/07/2014 at 10:07 point
Hi Rui, your is very interesting project. I'm on an Arduino based smarthome framework, that create a local network on boards, it would be nice having your work on the server side.
https://hackaday.io/project/3497-arduino-smarthome-and-iot-networking-framework
Moritz Walter wrote 02/26/2014 at 20:52 point
Nice work, almost looks like some kind of Arduino Web Firmata!
Rui Santos wrote 03/07/2014 at 12:01 point
Thank you!
I just released a new tutorial for that platform, I would love if you could take a look.
Here's the tutorial: http://randomnerdtutorials.com/arduino-control-220v-lamps-from-anywhere-in-the-world/
