Atari 2600 Bankswitch Cartridge
A ROMless cartridge with internal selectable bankswitch for 8/16/32K games and a DIY ROM friendly connector.
The concept of this project is so simple that I can not imagine why do a similar project haven't appeared in a form of a product during the golden era of Atari, when TTL chips were not so cheap.
Three bankswitch schemes are implemented: F8, F6 and F4 selectable by pins on the output connector. Then a new game is simply a ROM with one or two wire connections to select the proper bankswitching schemes.
The Bankswitch cartridge implements the three most common schemes named F8, F6 and F4. The working of the bankswitches is depicted on the table below.
Address  -Address Lines--   Bankswitch/Bank selected
         1 11               8K    16K   32K
         2 1098 7654 3210   F8    F6    F4
$1FF0 0001 1111 1111 0000   -     -     -
$1FF1 0001 1111 1111 0001   -     -     -
$1FF2 0001 1111 1111 0010   -     -     -
$1FF3 0001 1111 1111 0011   -     -     -
$1FF4 0001 1111 1111 0100   -     -     0
$1FF5 0001 1111 1111 0101   -     -     1
$1FF6 0001 1111 1111 0110   -     0     2
$1FF7 0001 1111 1111 0111   -     1     3
$1FF8 0001 1111 1111 1000   0     2     4
$1FF9 0001 1111 1111 1001   1     3     5
$1FFA 0001 1111 1111 1010   -     -     6
$1FFB 0001 1111 1111 1011   -     -     7
$1FFC 0001 1111 1111 1100   -     -     -
$1FFD 0001 1111 1111 1101   -     -     -
$1FFE 0001 1111 1111 1110   -     -     -
$1FFF 0001 1111 1111 1111   -     -     -
Then:
- F8 bankswitch uses 2 regions of 4K selected by bit 0 of the address lines.
- F6 bankswitch uses 4 regions of 4K selected by bits 3 and 0 of the address lines.
- F4 bankswitch uses 8 regions of 4K selected by bits 3, 1 and 0 of the address lines.
By using two configuration pins it is possible to force the levels of address lines 3 and 1 at the input of the bankswitch register in order to select the desired scheme. By forcing A3 and A1 it is possible to use the F8 scheme (8K). For 16K games A1 is kept constant and the bankswitch is the F6. At last, if neither A3 nor A1 is selected the F4 bankswitch enables the use of 32K games.
Schematic:
The schematic of the bankswitch is on the picture below. Notice the delay RC network from the output decoding to the address latch as well as the reset circuit on the /CLR pin of the LS174.
Bankswitched cartridge connector:
The bankswitched cartridge connector inherits the pinout of the original cartridge but has some extra pins for the extra address lines A12~A14 as well as a pre inverted A12 (Chip select). It has also two bankswitch selecting pins.
The bankswitch scheme can be selected by connecting the jumpers
 JP1     JP2   ROM Size
 open    open   8K (F8)
 close   open  16K (F6)
 close   close 32k (F4)
                         /BSF8-|1   34|-
                         /BSF6-|2   33|-
                         /BSF4-|3   32|-
                      /A12 /CS-|4   31|-AA13
      +------+            AA12-|5   30|-AA14
   A7-|1   24|-sGND         A7-|6   29|-sGND
   A6-|2   23|-VCC          A6-|7   28|-VCC
   A5-|3   22|-A8           A5-|8   27|-A8
   A4-|4   21|-A9           A4-|9   26|-A9
   A3-|5   20|-A11          A3-|10  25|-A11
   A2-|6   19|-A10          A2-|11  24|-A10
   A1-|7   18|-A12          A1-|12  23|-A12(not bankswitched)
   A0-|8   17|-D7           A0-|13  22|-D7
   D0-|9   16|-D6           D0-|14  21|-D6
   D1-|10  15|-D5           D1-|15  20|-D5
   D2-|11  14|-D4           D2-|16  19|-D4
  GND-|12  13|-D3          GND-|17  18|-D3
Particularities of the 32K cartridge
Due to the fact that the lines A12,A13,A14 are not consecutively connected to A0,A1,A3 but to A0,A3,A1 the blocks 2 to 5 on the 32K cartridge appear to the game out of its sequential order on the ROM.
Instead of blocks: 0,1,2,3,4,5,6,7 (A12<=A0, A13<=A3, A14<=A1)
we have the blocks: 0,1,4,5,2,3,6,7
To workaround this issue there are two alternatives:
  • Split the ROM file into 8 chunks of 4K and reorder them in the 0,1,4,5,2,3,6,7 order
  • Switch the lines A13 and A14 in the ROM cartridge
  • Hand Routed PCB
    danjovic09/03/2016 at 19:24 0 comments
    I've just routed the PCB for the bankswitch cartridge. The routing was manually done and it took some time to optimize the disposition of the TTLs as well as the pins and gates of the NAND and NOR chips so the board can easilly be built at home (or in cheap PCB manufacturing services). All tracks are 16 mils and no unnecessary via have been used.
    There are still some room for improvement ,though.
  • Updated schematics
    danjovic08/04/2016 at 02:34 0 comments
    Updated the schematics to allow bankswitch selection from external logic levels on BS0,BS1 pins instead of simple wired-or configuration. One chip was added but 4 diodes and three resistors were eliminated.
    A PLD version is also being considered. It will be considerably simpler to implement, but without the same retro appeal.
View all 2 project logs
freefuel wrote 12/23/2018 at 23:58 point
A matrix decoder could be created with a latching device and another EPROM to create any sort of addressing method you pleased, including 1K banks remapped to any address range. as well as masking out unusable address space, for example creating an overlay mask for the lower 4KiB of address space below the normal cart range by preventing EPROM data output at specific addresses to prevent bus collisions.  while using a pair of EPROMs the overall parts count would be reduced the advantage here is the simple method of changing the addressing system involving minimal if any board changes.
freefuel wrote 10/14/2020 at 16:33 point
having thought about this some more, it's just as easy to employ some diodes to mask out hardware addresses. this would provide access to nearly the entire 8KB ROM without bank switching.
Artur wrote 12/07/2016 at 18:31 point
I would like to test this circuit in the PLD version, did you get to create the PLD?
rnjacobs wrote 08/06/2016 at 18:23 point
My favorite amazing hack for 2600 bankswitching is this one (in Portuguese):
http://web.archive.org/web/20160508011021/http://victortrucco.com/EmuladorDeCartucho/Atari2600/tutorial
He's using a 'PROM as programmable logic, and adds feedback paths from the ROM's data outputs to its address lines to serve as latches to hold the current bank
