How did I start all this?
A project log for Home automation: thermostat with ESP8266 & OpenHab
A project about Home Automation. I want to replace my old thermostat with an IoT ESP8266 + OLED 128x64 Screen + OpenHab + MQTT + Micropython
jorgeJorge 08/03/2016 at 11:160 Comments
Mi first step was to make things work, one thing at a time.
I started with the DHT22. Very easy in micropython as the library is already included.
Then I stepped to the OLED 0,96" screen. Try to show some simple messages using the library from https://github.com/micropython/micropython/tree/master/drivers/display
Then I stepped to MQTT. Once you understand the way it works, it won't be problematic but when I put everything together had some memory issues. I had to keep the OLED out for a while until I figured out how to maintain my memory usage low.
The best tutorial I've found to understand MQTT is this one: https://www.linux.com/news/mqtt-building-open-internet-things
The last thing is OpenHab. I'm into this at the moment...
