Code
A project log for NASA Wind Decoder
This is a small project to decode the LCD Repeater output from a NASA Marine Wind indicator and to upload the data to a NMEA0183 Server
neilneil 08/19/2016 at 14:450 Comments
This project is written in micropython and can be be found in the following github repositories:
Main code - https://github.com/coylen/espWIND
Other dependencies that are shared with the rest of my micropython NMEA codebase - https://github.com/coylen/upyNMEA
The only additional complexity is that I have had to develop a custom Micropython ESP8266 build to incorporate some very limited I2C Slave support. This is added to Micropython as a driver and can be downloaded and built from https://github.com/coylen/micropython. There is still some work ro be done with this to make the code more robust and timeout as currently it will hang until the circuit sees at least some I2C traffic.
