Going for the SIM800 module and arduino mini pro
A project log for Water Temperature Arduino GPRS
Messuring water temperature with ds18b20. Sending it all to thingspeak.
marin-bMarin B. 08/29/2016 at 05:190 Comments
During my tests the arduino mini pro 3.3v and the sim800 module use a lot less power.
Currently im running them on a tiny solar panel and a bad 600mAh battery that charges up to 60% max.
So i have made a all in one pcb to make my final project.
I will use a on board solar charge controller CN3065 and a MCP1700 so i can unsolder the regulator off the arduino mini pro. This regulator is much better for this use and uses much less power.
