Two Stage Tentacle Mechanism
A Fresh Approach to Richard Landon's Design using Delrin and a Laser Cutter
I could spend hours poring over the mechanisms and electronics that lie beneath the animatronics of the film industry. I figured you might like them too, so I decided to start building one and appending instructions once complete.
This design takes the sneak peek at two-stage mechanisms from the Stan Winston tutorial and completely fleshes it out with my own design using a combination of laser-cut and off-the-shelf parts. (Ok, there were a couple 3D prints, too!)
To my fellow surgical-robot-and-animatronics enthusiasts, stay tuned!
Preview Video!
  • Mission Log: Getting in a little Practice
    Joshua Vasquez08/20/2016 at 05:54 0 comments
  • Two Stage Testing
    Joshua Vasquez08/13/2016 at 20:31 0 comments
    With the second controller built, I connected it to the tentacle last night and gave it a whirl. It worked!
    It looks like I'm going to need a rigid mounting fixture to prevent the base from twisting. I also had to be very particular with the arrangement of the cable housings (extension spring in this case) such that they don't cinch or rub against each other while the tentacle moves. With the proper base fixture, I can probably solve both of these issues to make mounting a snap.
View all 2 project logs
josmar barbosa wrote 10/25/2016 at 22:31 point
...no, for me its simplely doesn't work
Jarrett wrote 10/25/2016 at 18:54 point
I've been trying to come up with a cheap alternative to those hubs, though. They're like $8 each!
Especially a solution that can be found locally or on AliExpress instead of McMaster.
phil wrote 10/25/2016 at 18:44 point
Videos worked fine on mobile for me. Like your design. Was working on something similar for a project of my own but yours is much more minimalistic compared and is just the right amount of creepy.
josmar barbosa wrote 10/25/2016 at 18:06 point
Buddy! It can't play videos.
ActualDragon wrote 10/25/2016 at 21:10 point
it says its restricted :(
