Progress! Even if it's a little bit
A project log for Science Tricorder by Olympus Heavy Industries
A multi-mode scanner and data logger based on Adafruit Feather & Arduino
queadlunnQueadlunn 02/16/2020 at 21:020 Comments
Started to wire the mainboard together, even if slowly. I'm currently working on getting all of the power stuff connected up first, then I'll do the data connections. I plan on getting the mainboard working first, then working on the sensor array assembly. Slow going but it's progress!
Thanks to Mit Balkens (https://hackaday.io/MitBalkens) for pointing out the correct hinges, I've updated the Thingiverse page and the downloadable model pack here with the correct information.
