The Hardware: Finishing the EEG Device Build
A project log for OpenLD: Lucid Dreaming Research Platform
An open source platform to help induce and explore the realm of Lucid Dreaming for Research and Personal Well-being
jae-choiJae Choi 08/30/2016 at 16:320 Comments
Here is the finished prototype with an enclosure
The device in operation with a USB portable power supply
The electrodes will be connected to the female connectors located on the left side of the EEG device. Since this hardware uses a Bluetooth connection, it is fully portable. This also helps with the safety of this design, as it has absolutely no electrical connection to the 110V/220V mains for power.
In the future, a custom 3D printable case will be designed. But for now, I will focus on getting this platform up and running, as the software side of this project is where the real challenge lies.
This pretty much concludes the 1st revision hardware build for this project. It is now time to write some code for obtaining and processing the EEG data. In the next post, I will post the code for the ARM processor and measure the performance of this EEG Acquisition device.
