Up Conversion Reactive INK uses
A project log for Invisible QR Code Navigation for Robots 2020
Cheap UV invisible QR codes for indoor navigation of robotics. Print labels from Inkjet Printer and read with a normal camera.
josh-starnesJosh Starnes 09/14/2018 at 22:530 Comments
A variety of florescent particulate can be combined with Up Conversion IR inks in order to take a otherwise invisible bar code or QR code into a visible glowing readable beacon of light for robotics navigation and programming. In my case my application is both unique and useful. I regularly search for similar information about invisible marking methods like those in anti counterfeit measures.
https://phys.org/news/2012-09-upconverting-nanoparticle-inks-invisible-qr.html
Here is the first time I have seen this used specifically in the way that I have, but the specifics are kept secret, the postal service sometimes has UV reactive codes come through that use information to track mail outside just the address info.
