Lions long struggled with finding the library that contains a symbol. The UNIX gurus can do it with a find command & some regular expressions. Lions wanted a simple command to run, without any effort looking up regular expressions.
https://cdn.hackaday.io/files/1380505906331200/symbol.c
This only returns exact matches. It's easy to change it to match all occurrences & symbol usage. Forget about stripped libraries & macros.
