command line ffmpeg/mplayer wrapper program
A project log for Silly software wishlist
Motivation to do some software projects by writing them down.
lion-mclionheadlion mclionhead 07/03/2020 at 20:480 Comments
Lions originally wanted everything to have a GUI.  In old age, lions just want as much computing power devoted to the task as possible instead of the interface.  After writing a video editor, lions have accumulated many usages of ffmpeg & mplayer  from the command line.  The mane use of mplayer is extracting decompressed audio.
mplayer -ao pcm:file=audio.wav -vc null -vo null
But specifying the output file doesn't work.  ffmpeg has a usage which extracts decompressed audio, but this works for fewer sources.
ffmpeg -i <input file> -vn <output file.wav>
Then there's extracting the audio from a movie without any transcoding.
ffmpeg -i <input file> -vn -acodec copy <output file>.mp4
Extract the video from a movie without any transcoding:
ffmpeg -i <input file> -an -vcodec copy <output file>.mp4
The other thing lions use ffmpeg for is transcoding video from a variable framerate to a fixed framerate file.  This degrades the quality, but if the specified bitrate is higher than the input bitrate, it'll encode as high as the input bitrate.
ffmpeg -i <input file> -c:v mpeg4 -vb 5000k -an <output file>
Lions use ffmpeg to encode from an uncompressed source, for debugging machine vision programs.  This isn't as fast as linking ffmpeg & calling the functions with a memory resident frame buffer but it's simple.
ffmpeg -y -f rawvideo -y -pix_fmt bgr24 -r 15 -s:v <width>x<height> -i - -c:v mpeg4 -vb 5000k -an <output file>
It would be a lot simpler if these most common ffmpeg usages were condensed into yet another wrapper program.
