It lives!
A project log for The Metabolizer
A living recycling center that eats trash and sunshine and poops recycled plastic objects
sam-smithSam Smith 04/24/2018 at 04:190 Comments
It doesn't run on char-gas yet, but it does power the shredder no problem. And later (not pictured) I hooked up the generator and was getting around 40VDC at full throttle, 20ish at idle. Those are promising voltages because they can easily be handled by a charge controller designed for solar.
