A project log for AquaPic - Aquarium Controller
Reef tank controller used to monitor various parameters such as temp and pH, and also control equipment such as pump and lights.
skyler-brandtSkyler Brandt 08/14/2015 at 12:150 Comments
I've ordered my first batch of boards. The dimming, and power strips PCBs are on the way from someplace in China. I went as cheap as possible so they'll take a little bit to get here. In the mean time, I've written an application the combines all my build material excel files into one master list. Right now I'm just doing silly little things on the project as I wait to slowly buy things.
Edit:
Apparently some PCB manufactures don't like when you pre-panelize a gerber file and will charge a "fee" in such occurrences. I was dinged with an extra $15 because the Power Outlet PCB was four copies on one board. The middle man I went though was really helpful though. He said that if I ever need to do that again, that he has another factory that will accept panelized PCB's for just a little extra. They will also cut out each board.
