Prism Dimension Calculator and More Lexan
A project log for 'Holographic' Projection
Collection of software for projecting 'holograms' onto a reflective prism using a computer monitor.
billy-stevensBilly Stevens 09/26/2016 at 15:480 Comments
I've added a prism dimension calculator to my portfolio website. The calculator takes in the aspect ratio of a sheet and produces a template for cutting prism sides. I've also put in an order for a larger Lexan sheet. That way I can experiment with alternative ways of constructing the prism, such as bending the sheet or 3D printed fittings. This will be a big improvement over the hot glue and masking tape that holds my current prototype together.
