Helps you save water by turning red after one Liter
There are so many amazing things that you can add in it you can click on the water heater and learn about the best water heater.
Thanks. An enclosure would definitely help.
I like the visual aspect along with the water conservation theme. Is the unit water proofed or water resistent? I assume there is an enclosure to prevent the Arduino board from getting wet.
Currently working on: https://hackaday.io/project/4698-clouden
nodemcu12ecanada
Gholamreza Izadpanah
Anteneh Gashaw
dannyvai
Yes, delete it Cancel
You are about to report the project "Augmented Water", please tell us the reason.
