Yet Tweaking
A project log for 32 Shades of Grey
Portable NTSC test pattern generator
danjovicdanjovic 05/22/2018 at 01:180 Comments
Replaced the "DAC" resistors with an association to get more precision. The association values have been calculated using an online tool (link)
Desired Value (Ohms)Association (Ohms)
31313k3 // 56K
15631K + 560
780390 + 390
390390
195390 // 390
211220 // 5k6
187220 // 1k2
Nevertheless, the shades yet were not gradual at the center. After some tweaking adding resistors in parallel I've managed to figure out which resistor in the network was disturbing the "linearity" of the output. It happened that to be the 195 Ohms resistor association. Few experiments later I have added a 120 Ohm resistor in parallel thus resulting in 75 ohms (sic) but I've managed to get a good image.
Linear gradients on a 46" LCD TV set
Linear gradients on a 5" B&W CRT TV set
It didn't occurred to me at the moment but maybe there is one bit flipped either in software or in the circuit.
Series and parallel association of resistors
