Design 3: Camera mounting
A project log for Simple ROV waterproof cameras
3 attempts to build simple and cheap waterproof ROV cameras
tim-wilkinsonTim Wilkinson 09/28/2016 at 20:370 Comments
Mounting the camera in the GoPro box is a little trickier. The easiest solution was to 3d print a mount which fits snuggly inside the box and has a hole to mount the camera. The design is here http://bit.ly/2drxVC4.
The design has legs to stabilize the mount inside the box and keep the lens a fixed distance from the box surface.
Here is the final result with the camera and video balun inside the GoPro box.
