Specs
A project log for Solar water heater monitor
Monitor and log temperature of wood fire boosted Solar hot water heater
saabmanSaabman 09/25/2016 at 01:060 Comments
I Would like to monitor
Use a Node MCU Board
5 DS1822 water proof Sensors
From experience using the NODE MCU board running a logging system updateing a BLYNK server every 2 seconds a 12V 12AH SLA last about a week.
I dont think I need that kind of resolution so will initially set the update rate to once every 15minutes and put the ESP8266 to sleep between updates. As I will me monitoring the battery voltage I will be able to reasses the energy requirements once I start to obtain real data
