Got the CPU working. The video is very lame (shot on my iPhone - unfortunately low res). But the point is, the TMS99105 actually runs and executes instructions! CPU external clock is still 20MHz, so machine cycle time is 200 ns (runs at 5MHz).
There are 8 LEDs on the Pepino board. These are controlled by the CPU. The software listing is below after the video. The program resides on the external RAM chip on the Pepino board. The FPGA demultiplexes the address / data bus and arbitrates access between CPU and serial port loader.
And here is the firmware listing (sorry for the lack of comments). There is one write only IO port at >8000, the top 8 bits are connected to the LED drivers.
* Erik Piehl (C) 2016 October * boot99105.asm * * Compile with: xas99.py -b -R -L list.lst boot99105.asm * Load with: ../memloader/memloader 0 boot99105_0000.bin * IDT 'BOOT99' WRKSP EQU >1000 OUTP EQU >8000 AORG 0 DATA WRKSP,BOOT BOOT LIMI 0 ; BOOTLP ; JMP BOOTLP ; NOP ; NOP ; JMP BOOTLP LWPI WRKSP LI R1,OUTP LI R0,>100 MAINLOOP MOVB R0,*R1 SLA R0,1 JNE ! LI R0,>100 ! CLR R2 !delay DEC R2 JNE -!delay JMP MAINLOOP SLAST END BOOT
