HP touchsmart 310 IR touchscreen to USB
My HP touchsmart 310 is dead but the screen and IR touchscreen works perfectly.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Took a look at the touchscreen controler when i was salvaging stuff from the dead AIO pc.
It had 5 wires like most sheilded usb cables do. 2 for GND, VCC, DATA+ and DATA-
Usually they are colorcoded BLACK, GREEN, WHITE and RED.
One of the touchscreen wires was GREEN so i started from there. I probed out two GNDs and found the VCC by powering the dead motherboard. The motherboard has a dead GPU so no screen output but poweres on normally othervise.
Now i had to guess between the two wires witch one is DATA+ and DATA-.
Then i guessed and got it right the first time. The HID touchscreen controller showed up in my device manager when i pluged it it and registired touch input.
Everything is in the pictures.
