How to connect Pedalino to a WiFi network
A project log for Pedalinoâ„¢
Smart wireless MIDI foot controller for guitarists and more.
alf45taralf45tar 06/01/2018 at 08:540 Comments
AppleMIDI and Open Sound Control (OSC) protocol requires a network connection. Pedalino support IEEE 802.11 b/g/n Wi-Fi with WPA/WPA2 authentication (only 2.4 GHz).
Pedalino implements Smart Config technology via Espressif’s ESP-TOUCH protocol to help users connect embedded devices to a Wi-Fi network through simple configuration on a smartphone.
Tested apps for configure SSID and password are:
Boot procedure
You can reset the last know access point via menu.
