New pulley wheel
A project log for Icepick Delta
A highly experimental open-source 3D printer with a rock bottom bill of materials
ttnTTN 12/20/2014 at 19:520 Comments
The original upper pulley wheels where fine, but it was difficult to tension the belt. So I redesigned them:
The new pulley design has a piece in the lower right section for tightening the belt by screwing in the screw:
The upperarms are also less prone to catching on the lower arms when homing from varying positions.
