Timing Board
A project log for 8 Bit TTA Interpreter
TTA (Transport Triggered Architecture) is very simple CPU type.
agpcooperagp.cooper 05/31/2018 at 02:040 Comments
Timing Board
I have added a Timer to the Timing Board. The timer triggers an interrupt every 256 instructions. If I use a 20 MHz crystal fro a 10 MHz clock (the max!), then an interrupt is triggered at 9766 Hz which is close enough to 9600 baud for a serial interface (for later).
I have also moved the interrupt register onto the timing board to free up a bus line for a Serial Clock (SCLK). The timer uses INTR7 (the highest priority) which is not longer accessable from the bus.
Here is the EasyEDA Schematic:
Only three boards remain:
Then possibly a Serial Board.
Modified the timing board for 16x the baud clock as I found a schematic for serial input:
(Source: http://digitarworld.uw.hu/circuits.html).
AlanX
