Sensors - Absolute Magnetic Encoders
A project log for 3D Printed Robot Actuator
A high speed and high torque robotic actuator using low-cost brushless motors, custom controller, 3D printed parts and bearings.
paul-gouldPaul Gould 05/10/2018 at 16:050 Comments
The position sensor board uses the AS5147 is a 14-bit Magnetic Encoders
One for is used for the motor electrical position/angle. One is used for the joint position/angle. The are connected via daisy chain on SPI communication with 2x 16bit clocking. There is a piece of Silicon Steel between the two sensors boards to prevent cross flux of diametric magnets.
The technical information for the system:-
This basically means that they are quite suitable for this application.
The Schematic and PCB has been uploaded to the "file page".
