Started PCB assembly
A project log for Mechanical GKOS keyboard for phones and tablets.
A no-compromise, mechanical switch, 6-button chording keyboard, placed on the rear side of a tablet or a mobile phone.
ptravptrav 08/22/2018 at 05:350 Comments
My PCBs from Allpcb.com and the components have arrived a while ago, but I had to delay the assembly due to some unrelated stuff.
Finally the assembly have started.
The PCBs are in excellent condition -- AllPCB quality, as always, very good:
 The final wiring diagram is as following:
Each of the 6 rear buttons has an optointerrupter, with the LED connected to the corresponding Arduino pin via  a 1.1К resistor, and the photo-transistors connected to the pin 15 in parallel. The pin is pulled up by 10K resistor. To test a certain button, Arduino momentarily pulls up the control wire of corresponding LED, waits for 1 ms, then reads voltage on the pin 15. If the switch is "not closed" (that is no chopper between the LED and the photo-transistor) pin 15 will be low. If the switch is "closed", wire will be high. After switching the LED off, Arduiono further waits 1 ms, so the photo-transistor can lock completely, after that, the next button is tested, and so on.
I preferred this method over constantly shining LEDs on the photo-transistors, as only one LED is lit at the time, thus the LED power consumption is 2 mA instead of 12.
In the original PCB I made a mistake wiring 5V to the Arduino directly and not through the USB port. It was discovered that without 5V on the USB pin 1 Arduino Micro Pro does not connect to the PC. I fixed this by soldering the 5V wire to the board and cutting the trace to Arduino pin.
Another minor issue was the power switch position, which was too far from the PCB edge. I fixed it by adding some extra wires to the switch.
The updated PCB version:
