Firmware Testing
A project log for Zero A9G GPS tracker
Makerfabs Maduino Zero A9G GPRS/GSM/GPS tracker.
makerfabsMakerfabs 06/07/2018 at 11:000 Comments
today i write some small firmware to test the module if it works as intended. firstly i just make it get the GPS signal and display my location on my PC:
#include<stdio.h>
#include<string.h>
#define DEBUG true
  int pon=9;
  int poff=6;
  int lowp=5;
#include<stdio.h>
#include<string.h>
#define DEBUG true
  int pon=9;
  int poff=6;
  int lowp=5;
void setup()
  pinMode(pon, OUTPUT);
  pinMode(poff, OUTPUT);
  pinMode(lowp, OUTPUT);
  digitalWrite(poff, LOW);
  digitalWrite(lowp, HIGH);
  digitalWrite(pon, HIGH);
  SerialUSB.begin(115200);
   while (!SerialUSB) {
    ; // wait for serial port to connect
  Serial1.begin(115200);
  digitalWrite(pon, LOW);
  delay(3000);
   delay(5000);
   sendData("AT+GPS=1 ",1000,DEBUG);
void loop()
    sendData("AT+GPSRD=1",1000,DEBUG);
   delay(1000);
String sendData(String command, const int timeout, boolean debug)
    String response = "";
    Serial1.println(command);
    long int time = millis();
    while( (time+timeout) > millis())
      while(Serial1.available())
        char c = Serial1.read();
        response+=c;
    if(debug)
      SerialUSB.print(response);
    return response;
in 30 seconds, it output as:
it means:
The UTC time: 035442;
The valid location: A,means yes
And my location: 2235.5484, Northern Hemisphere and 11351.4722, East longitude;
and follows some charators, i do not quite understand, and care;
and date: 070618(date/month/year)
