Updated to V3
A project log for Zero A9G GPS tracker
Makerfabs Maduino Zero A9G GPRS/GSM/GPS tracker.
makerfabsMakerfabs 08/30/2019 at 09:240 Comments
Updates in the version 3:
1. Power circuit update: previously a 3.7v battery is needed as the A9G power supply.
in the new version 3, the module can be powered either by battery , or directly by USB.
2. Battery voltage Monitor, to check the battery voltage
3. USB voltage monitor, to check if there a USB power connected;
4. 3.3V DC-DC module updated to 1A Version
5. Power switch added , to power on/off the whole module.
