Bug found
A project log for konijntje-thermo-humi
Gadget that shows room temperature & humidity on a LED-bar
christoph-tackChristoph Tack 01/20/2022 at 20:480 Comments
After wake-up the software no longer ran correctly.  The only thing I could do was force a software reset using the watchdog timer.
The issue was due to powering down internal peripherals of the ATTiny prior to entering power down mode.  At wake-up these need to be re-enabled, which I forgot.
