The whole electronic circuit works off a regulated 5V DC supply.
This project will draw your attention to the tiny microcontroller PIC12F675 from Microchip. What are the features of this chip, available in traditional (PDIP) and SMD (SOIC) packages?
- Only 8 pins, total 6 I/O ports
- Integrated Memory-Clear (MCLR) into one of the I/O ports
- Its own internal RC oscillator
- Operates from 2.0 to 5.5 Volts
- Built-in Analog Comparator and Analog-to-Digital Converter (ADC)
- Includes two timers, one 8 bit and one 16 bit
This is the tested schematic diagram of the toggle switch. Ready-to-use hex code is also included to expedite the construction process. However, due to commercial reasons, source code of this little project is not published here at this time.
