Schematics for IMUs / 3D Accelerometers
A project log for Lighthaus
Earthquake detection & early warning systems
ryan-logsdonRyan Logsdon 07/23/2018 at 03:210 Comments
We're making progress towards reading our 7 different accelerometers / IMU chips.
At the moment,  we've wired up & are reading the I2C data from the following three chips:
The ones we're still working on are:
And the 7th chip, an STMicroelectronics LIS3DHHTR, is out of stock with a 14 week lead  time, so we're ruling that chip out before spending any more time on it.
Now for a walk-through of the pin layouts.  The controllers are all Arduino Pro Mini boards, and the "IC"s are the respective Kionix and ST chips.
KX022
resistors are 1k Ohm
capacitor is 0.1 uF
KX112
resistors are 4.7k Ohm (1k is fine as well)
capacitor is 0.1 uF
LIS3DSHTR
resistors are 330 Ohm
capacitors are 0.1 uF and 10uF
