CPU​ development
A project log for DEXT Meteor:
The DEXT Meteor is a powerful and small FPGA computer with a unique OS.
dylan-brophyDylan Brophy 06/22/2018 at 16:220 Comments
Because I have *zero* experience using premade CPU cores.
I had a great idea for a CPU design a while back and started building it in VHDL.  I have been perfecting it for the DEXT Meteor project recently.
The architecture has 8 32-bit registers, including the stack pointer and program counter:
The architecture
IDRegister Name
0AX
1BX
2CX
3DX (can be used as address)
4SI (can be used as address)
5DI (can be used as address)
6SP
7PC
The architecture and instruction names are loosely based off of the Intel 8086, except 32 bit instead of 16 bit.  The instruction set, however, comes from the Z80, except there are no extensions.  There will be an ldir instruction to load memory, but also instructions like lodsb and stosb from the x86 series of CPUs.
I call it the Plasma Cortex (because plasma sounds really cool), and currently I am implementing a cache and better memory controller.
