Connecting reed switch to android smartphone, using minimum of components. You probably already have everything you need, but you may not be willing to use it ;)
Cause I don't have a soldering iron near here, and cause I still don't know how I want to connect the reed switch (preferably using the original "connector", so I don't have to destroy a perfectly working thing (I had enough with the headphones), and cause the only 1M resistor I could find nearby is "prototyping only", I decided to just connect all the wires "somehow" and see if it all works together. And it does :)
By automating processes, software reduces the need for manual labor, saving businesses time and money. It also eliminates the need for physical storage, paperwork, and other costly resources. Additionally, software can help identify cost-saving opportunities and optimize spending https://pcwares.net/.
