New Year, New Prototypes, New Problems
01/13/2019 at 07:26 • 0 commentsAlthough I have ordered PCBs several months ago, they have only been delivered this week!
The boards quality looks good to me!
So I proceeded to assemble the Baseboard, everything went smoothly. The Phoenix connector fits perfectly, I had to move some connectors but in this way I got:
- The shorter board of 1 mm
- SMD components all from one side
As already mentioned, reducing the size has also caused some boredom on other boards. One of these is the programming card.
The latter has been updated to have a USB / Serial adapter so as to reprogram the Atmega 328p on the fly.
In addition to serial programming, the programming module has pogo-pins to write the bootloader to the MCU.
The board works perfectly, pity for a small mistake: I have not moved the pogo pin pads after resizing the baseboard, this translates into having the pins diagonally. (The important thing is that it works)
NB-IOT, the module is assembled, AT commands the SIM7020 module responds correctly but I can not connect to a network. I'm looking for information at local TLC to understand if I need a particular sim.The board itself with the SIM800C should work perfectly! (I have not yet been able to assemble one)
The final result:
Happy New Year
12/31/2018 at 11:14 • 0 commentsUnfortunately due to the various holidays all shipments are delayed and I could not make a new prototype in time to end this 2018 with a working board.
But I made some progress with the Atmega 328 firmware. I can read and write on the slave UART. For now no interrupt only polling.
Greetings,
hitech95 -
Some more firmware progress, new PCB has been shipped!
12/10/2018 at 14:17 • 0 commentsToday I have received the LTE NB-IOT modem for the project and I figured out that I forgot to upload a video about the firmware development.
I'm not sure why I missed to upload ad update video, I had to format my PC due to a annoing windows bug!
Anyway, this is the video: -
Old changes, new 3D design!
11/12/2018 at 17:44 • 0 commentsSome time ago I changed the size of the boards because I had noticed that the thickness of the electronics box was too thin. Not being able to change the size of the box I opted to edit the one of the pcbs.
Only one millimeter in width has caused quite a few problems. (Shield redesign and I had to move components around on baseboard)
My poor skills in the parametric cad did not help, after altering the parameters the model was "broken". I thus proceeded to start from scratch.
Adoring the music and having taste for particular machines I discovered the MMX project (in reality, I have been following the project for a long time), the author of this project has recently made available a spreadsheet to create a PBS.
I then entered all the information of my project into a new sheet based on the one published by Martin and taking advantage of the features now I can easily see what there is and there is no need to do!
Taking advantage of the 11.11 sales, I have bought some new parts for the project, at this moment I'm compiling the BOM to then order the new PCBs.
Say "HI" to the SIM7020, Raúl Luna first suggestion was to use an LTE modem, although in Italy the GSM network is still active and will still be due to some very old infrastructures, I decided to try this module.
It should be compatible 1:1 with the old SIM800C (So I don't have to redesign the board again!), maybe the AT commands will be different, I'll have to find out as soon as I get the module!
The development of the firmware continues, now it is possible to read and write the 1Wire EEPROM through the slave processor.
I still have difficulty implementing interrupts for the Serial, and reading from serial. Perhaps this time I complicated the project too much!
A journey on making a custom SBC
11/08/2018 at 20:05 • 0 commentsHi, as you may have noticed from the title of this thread I'm working on creating my own SBC. You will wonder why this crazy idea, when the market is full of these products. Unfortunately all the products already present in the market are "huge" compared to the dimensions that I need to respect. (Some are just a couple of mm off )...
Initiallyct my project was meant to use the SOM "C.H.I.P. Pro" but, as many will know, they went bankrupt.I do not need a lot of processing power, the only fiew requirements are:
- No SD card for boot, but eMMC or Nand
- I2C bus
- SPI buses to drive a Display (at least one, the second could be using gpio bit-banging)
- Analog or Digital Audio. (If analog I need a microphone input)
- The need to have at least one armv7 due to some closed source libraries that I will have to use.
- Fiew GPIOs
- Wireless connectivity
I started looking at other SBCs in the market, many had only the SD, or a NOR SPI.
Initially I wanted to use a MIPS chip (like a mediatek MT7688 or MT7628) for convenience and available choices... but mother Google did not allow me because of its proprietary library.
I kept looking. By now disappointed by the solutions I started to print some SoC product briefs. I am an open source lover and for this reason I opted for Allwinner. (Despite the poor collaboration of the company the sunxi community has done a really good job on porting the drivers to mainline linux and datasheets are avilable for free).
I started reading the datasheet for my selected chip the R16 or the A33 and with a little patience I started to realize the wiring diagram. (I used a already made board to understand some stuff the datasheet provided/found on the net sucks at describing what some pins does/works).
Time passed and I was still deciding which interfaces to use, how much RAM and so on. Then I discovered the Neutis N5 module, they were doing what I had started. I remember that I was happy, just a few weeks left to release the board. Suddenly the date was moved, it kept changing month after month. Fed up I decided to resume the project of my SBC.Being a hobbyist I have always used Circuit Maker to make my PCBs, I have never had to use more complex software. (Before I used Eagle but Autodesk licensing ruined it). The project continued, and using a reference board similar to the one I wanted to realize I started to position the components, to create the nets and everything else. It's been less than two years since I started. From the initial project I had to make several changes: the most important was that manufacturers have discontinued the 8Gb RAM DDR3 chip, now there is a scarcity of 100nF capacitors and who knows what else will come out.
The Neutis N5 module is almost close to release (if they don't keep changing the shipping date) and so I no longer need to continue making this SBC. Al the work I did was done by a hobbyist, I'm not an electronic engineer, no one taught me how to make these boards. I used the informations available on the internet to document me. My SBC will not see the light of sun, because the production cost of that PCB is close to 2k with assembly and parts).
Today I'm stuck because of this Front board that is still a concept, and the fact that the Neutis module continues to delaydoes not bode me well.
Do you have any alternatives in mind?
I2C slave: Firmware testing
10/26/2018 at 21:44 • 0 commentsI'm testing out the firmware for the baseboard. Right now I have basic UART bridge (I have only tested the TX from Master to Slave) and the IO Expander functions. Interrupts are not implemented yet. I'm working on PinChangeInterrupts for the IO Expander.
This is part of the sketch of the master:
#include <Wire.h> void setup() { Wire.begin(); Wire.beginTransmission(42); // Transmit to device #42 Wire.write(0x02); // Write to the port direction register Wire.write(0xF0); // Register data Wire.endTransmission(); // Stop transmitting delay(500); // Some delay to make is easy to see on the logic analyzer Wire.beginTransmission(42); // Transmit to device #42 Wire.write(0x07); // Write to the TX buffer register Wire.write("HELLO!\n"); // Register data Wire.endTransmission(); // Stop transmitting } void loop() { bool changed = false; uint8_t byte_t = 0; unsigned long currentMillis = millis(); // See "Examples > Blink without delay" to understand how this work if (currentMillis - red_millis >= red_int) { red_millis = currentMillis; // Instead of writing the pin we toggle a bit on the register bitWrite(byte_t, 1, !state_red); state_red = !state_red; changed = true; } if (changed) { Wire.beginTransmission(42); // Transmit to device #42 Wire.write(0x04); // Port status register Wire.write(byte_t); // Port data Wire.endTransmission(); // Stop transmitting } }
Atmega as I2C slave
10/23/2018 at 19:26 • 0 commentsAs I have already said, Atmega allows communication with the various modules installed on the baseboard.
The functions of the chip are:
- IO Expander
- Serial bridge
- 1Wire Eeprom reader
My current aim is to emulate a simplified version of a pcf8574 and a MAX3107 so as to be able to easily adapt the linux drivers already present in the mainline.
While for the emulation of the PCF8574 I already have a working draft of the code (with the exception of the interrupt on the GPIO) the work for the serial bridge is more complex also because of the Arduino core.
In the last period I'm working on the functionality of serial bridge. I'm working on both the code and the documentation. I then decided to uplaod a draft of my registers map for my serial bridge.
Re-design of some boards
10/03/2018 at 19:38 • 0 commentsThe
What is going on with this project?
09/26/2018 at 23:51 • 0 commentsRaúl Luna asked me to participate in the project, as noted, joined the team; he has a lot more experience than me in modems. He immediately offered to help me fix the GSM module I created.
I redesigned the GSM module with his advice, while Raúl (Despite the tight deadlines of his project) took a few moments to create a more updated version of the GSM module.
Also I have been quite busy and I have not had the chance to continue the project.
Next step is to update the various boards and preparing a new panel to be implemented hoping not to find other mistakes! -
AT+CPIN? +CME ERROR: SIM not inserted
08/31/2018 at 17:18 • 0 commentsI started cheking power lines for the SIM, it wasn't fine with the multimeter. Then I checked with the scope and I got a similar resoult like this one.
According to that topic I moved on to see if there was some cold joints. In fact looks like that the module is really sensible of the soldering temperature. So I cheked the circuit with the multimeter and all was looking fine. I then tested with the scope each sim tray pin. And probing the DATA pin I got a simple pulse.... like a RESET.Dammit it happened again!
I have no idea how this could have happened but I reversed the two signals during the shematic phase of this board. (How can I have missed that, NO ERC was coming up)With a some patience I removed the SIM slot and soldered it with wires directly to the SIM800
At the end I got it working, I received the test SMS and the call.
I'm still testing all the features of the module, for now I have seen that some don't works:
- GSM Date & Time
- GSM Location
I'm not sure if it is due to the provider or the module itself. The antenna is also working fine the AT command replayed with a -60dBm as signal value. Also without the antenna the module is able to connect to the network but with a very low signal!
