Simulation with falstad
A project log for Precision current generator
A useful tool that injects small currents into your circuits, below the range of your usual lab PSU
yann-guidon-ygdesYann Guidon / YGDES 07/18/2018 at 17:540 Comments
Jim made a simulation on the online interactive simulator falstad, available there : http://tinyurl.com/ycj63egd
I've tweaked it a little (I display more values) :
$ 1 0.000005 7.619785657297057 65 5 50
t 224 240 176 240 0 -1 0.6771607865907852 -0.5873050244463638 500
t 256 272 304 272 0 -1 1.8738439949380101 -0.6771607865907852 500
r 176 304 176 400 0 10000
v 80 288 80 192 0 0 40 9 0 0 0.5
w 176 304 176 272 3
w 176 272 176 256 0
w 176 224 176 32 1
w 176 32 80 32 0
w 80 32 80 192 0
w 80 288 80 400 0
w 80 400 176 400 3
w 176 400 304 400 0
w 304 336 304 288 3
w 304 240 224 240 1
174 304 128 352 48 0 5000 0.9950000000000001 Resistance
w 176 32 304 32 2
w 304 256 304 240 0
w 304 240 304 208 2
w 304 128 336 128 0
w 352 80 352 128 0
w 352 128 336 128 0
w 256 272 176 272 1
w 304 128 304 208 1
r 304 336 304 400 0 250
The simulation is really useful and interesting:
For example the current through the 10K resistor varies very little, hence the voltage across it. That means that it could be increased easily.
The base current of the feedback transistor is very small, which explains the 0.6V across the potentiometer. This current is still above the range of the generator (220K limits to 5µA) but it could limit this value or affect the linearity of the circuit.
The base current of the pass transistor can be even lower !
The base voltage of the feedback transistor is almost fixed to 0,589V, it's pretty amazing (almost like a constant voltage generator, it's good to know !)
Thanks again @Jim!
Some tweaks show that the fixed resistor R1 can be increased to 100K in my case, with a bit of headroom. It's too late now but this would reduce the quiescent current...
However the feedback transistor is starved and its Vbe drops to 510mV...
