• 1
    code for arduino
    #include
    CustomSoftwareSerial* customSerial;
    void setup() {
    Serial.begin(19200);
    while (!Serial) {
    Serial.write("Mendooo Electronics");
    customSerial = new CustomSoftwareSerial(11, 10); // rx, tx
    customSerial->begin(19200, CSERIAL_7O1);
    void loop() {
    if (customSerial->available())
    Serial.write(customSerial->read());
    if (Serial.available())
    customSerial->write(Serial.read());
  • 2
    serial data reading
    change  baud rate of serial monitor to 19200
    move the potentiometer until you see something like ( 107393;000:0 ) on serial monitor
  • 3
    HC-06
    if you are using hc-06 bluetooth interface you need to change baud rate to 19200
    https://www.instructables.com/id/AT-command-mode-of-HC-05-Bluetooth-module/
