So What about this Shim?
A project log for The DEFCON26 Middle Finger Badge
a little gesture to let the facial recognition AI bots know of your disapproval.
el-jefeEl Jefe 08/17/2018 at 03:460 Comments
some of you got the shim in the white board and it looks something like this:
and the backside looks like this.
now, when you add the power backpack, the holes align as such:
see how the backpack can go either on the front or the back of the shim. your choice!
then you just have to figure out how you want to handle the sockets:
if you put them on the backside, be sure to solder the pins for the trinket in backwards! (while I didn't try this, it could work, good luck. but anyhoo)
ok now, see here: when you assemble the trinket with the shim, pay particular attention to the orientation of the usb notch, 2nd, you have to solder the shim to the pins to make a solid contact. go ahead and get creative if you have long pin sockets! but what I did here, what give it a quick solder tap on the 3 pins for vcc, gnd and usb, on the shim board, and them placed the trinket flush, and then soldred in the trinket.
so it looks like this:
now, if you don't want it to be permanent, you can probably make it pinned, and socketed, and make it stackable.
hope this helps some folks out there!
