Github links for Firmware and Bootloader
A project log for SAMD V2 Fusee Payload Injector
A mini SAMD21 board with CR2032 backpack. Can be used for fusee gelee or other DIY projects
electronrancherelectronrancher 08/10/2018 at 02:010 Comments
Here are the Github links for the source code used in this project.  If you want to go a-hacking, you will most likely want the Launcher firmware.  The bootloader code is included for those who are interested, but it's not needed unless you are starting out with a factory-fresh chip.  After the initial bootloader flashing, all further flashing of firmware, etc is done either through Arduino, or better yet - by dropping a UF2 file onto the USB device itself.  (Double click reset to open the USB firmware drive for drag & drop flashing)
Launcher Firmware Source Code (Arduino Sketch)
https://github.com/electronrancher/sam-fusee-launcher
Bootloader Source Code
https://github.com/electronrancher/uf2-samdx1
