Analog tilt sensors
A project log for Palm Power!
Control a robot with the twist of a wrist.
dennisDennis 08/14/2018 at 02:430 Comments
Build instructions are added showing the assembly of the DIY analog tilt sensors made from two potentiometers, scrap plastic and a couple of bolts and some nuts. The sensors will be used to detect the pitch and roll of a hand and used to command a robot to move forward, backward, left and right.
