Three designs with the AEM10941
A project log for Solar harvesting into Li-ion battery
This is a 0.8x0.6 inch board with AEM10941 solar harvesting IC charging a Lithium Ion battery
jasper-sikkenJasper Sikken 09/23/2018 at 11:340 Comments
In May/June I have designed the 1x1 inch Tiny Solar Energy Module to take part in the HackadayPrize2018 Power Harvesting challenge and won! And then I received a lot of interested in selling it. However since most projects have different power demands and people want to choose their own solar panel, I decided to remove the onboard solar cells and make two even tinier designs derived from the TSEM. They are both 0.8x0.6 inch small. The first is the AEMLION which is charging a Li-ion battery and the second is the AEMSUCA which charges a pair of supercapacitors.
I will be selling the AEMLION and AEMSUCA on Tindie for $24.90. At the moment ELecrow is working on 50 assemblies of each.
