Flexspline Racheting
A project log for Open HD
A high torque, high precision, Strain Wave Gear (harmonic drive) based 3D printable closed loop servo actuator for use in robotic arms
sam-armstrongSam Armstrong 10/03/2018 at 07:271 Comment
I thought this would be worth publishing a log about.
While preforming a load test I found that the flexspline will start to rachet if too much reverse torque is applied. I find this interesting, I was under the impression that the first mode of failure with this version of the flexspline would be the teeth shearing off.
I'll be working on a fix for this issue over the next few days. A few ideas in mind have are:
I've also been given a suggestion by Gabrael Levine, the designer of OpenTorque Actuator, to alter the wave generator geometry to keep a preload on the flexspline. I shall see what works best and include it in the next Open HD revision.
Margoz wrote 12/26/2018 at 11:19 point
If helps, I'm agree in using the most rigid TPU, the printed tooth profile should match exactly the belt tooth, also a preload would help.
But for me, also the key is to ensure that the belt is oil / grease resistant.
