Holidays MonoBLOC controller settings
A project log for DIY Wastewater Treatment Controller
Project goal is to build a controller for home wastewater treatment plant.
leszek-wojcikleszek-wojcik 08/21/2018 at 18:480 Comments
Holiday settings on MonoBLOC controller is enabled when no one is at home. In order to collect controller settings I've used same method as for nominal mode. Please refer to past log for getting more information.
Here is valve operation graph:
Here is pump operation:
Conclusion:
Unlike in nominal MoboBLOC mode air pump duty cycle is 50%. Air pump is enabled for 4 hours and then disabled for another 4 hours. Valve operates for 15 minutes per day. There is also short spike on valve which is probably for failure detection. See previous log for details.
