Controller v3
A project log for DIY Wastewater Treatment Controller
Project goal is to build a controller for home wastewater treatment plant.
leszek-wojcikleszek-wojcik 12/02/2018 at 19:470 Comments
Here is controller v3. There some improvements:
AC adapter I've selected is 12V version of Hi-Link. Based on specs it is suitable for -20 C installations:
Case meant to be water resistant (IP44) and uses wood screws. It was designed in such way there no screw hole going through the case except antenna and power supply case. Both power outlets are IP44 class. I'm pretty confident that whole case will meet my needs for water resistance.  You can find case project on Onshape. I will also put STL files into this project.
