Memory access modes
A project log for ECM-16/TTL homebrew computer
16 bit Computer made from ttl logic chips
pavelPavel 02/19/2021 at 09:060 Comments
Modes to have:
A. Immediate loads: values are inside instructions
B. Direct loads/stores: address is in instruction
C. Indirect loads/stores: address is in one of four Memory Pointer registers
D. Indirect loads/stores with offset: base address is in Memory pointer, while the 16-bit signed offset value is taken from General Purpose registers or from the word following the instruction
E. Indirect loads/stores with post-increment: same as C, only after memory access the memory pointer value gets incremented by value from GPR, or from the next word, or by one of pre-set values
F. Indirect loads/stores with pre-increment: same as D, but address in Memory Pointer gets updated before memory access
(probably some more?)
-- Loads and stores are to be mostly to and from General Purpose Registers.
-- Only way to load data into Memory Pointers and 8-bit registers from memory would be immediate values that are encoded into instruction.
