Redox codename Ultron pt.7
A project log for Redox keyboard
The Redox project is an open-source, QMK (Quantum Mechanical Keyboard Firmware) powered, ergonomic split mechanical keyboard.
mattia-dal-benMattia Dal Ben 09/19/2018 at 17:340 Comments
"Look ma, no wires!"
The battery holders finally arrived. I couldn't resist and soldered them right away.
Some solder is needed on the ground pad to contact properly with the battery.
Finally complete!
Just a quick check to see if everything works:
And now we wait for the case and the final assembly!
