... I almost forgot about the 3D printable case!
Since one of my goal is to make this keyboard affordable, I designed a 3D printable case in the past for the first revision. Now I'll do the same starting from the same case.
Here's some pics of the design:
The main difference in the case design from the past revision is the bottom half. For the Wireless version we don't need to be as high as before since we don't need to make space for USB connectors and such.
Here's the timelapse of the print thanks to my cousin Filippo, owner of the printer =D (Hephestos i3 MK2)
