I don't have a lot of time for working on my projects, but I was able to prepare something for the 2nd prototype based on standard D1 Mini modules
I'm not good at all on soldering, and I did a mistake with the D1 Mini Battery shield, so I had to remove and restart everything.
But at least now it's OK and working.
It's built around the ꝺeshipu's D1 Mini X-Pad, using only orginal Wemos D1 mini lite + shields. I have added a LiPo + one on/off button + some button caps.
These shields are very compact
It works :-)
Everything will be crammed into a standard 72x44x25 project box like this :
I know it's ugly but it's already better than the 1st proto :-)
Maybe I will be able to work on it in 1 or 2 weeks
